Hi have you solve this problem.I too get a negetive value .
Please confirm |
if your data doesn't fit wel the R-R distribution you can set different injection points/surfaces, each one with its diameter. Daniele |
im using surface injection with min and max diameter, But spread parameters i get a negetive value.
Im simulating a nozzle flow so i think point injection is not a correct choice.May be im wrong. I have a problem with stream formation. its splitting to half in the midair. is it something to do with Particle parameters. |
Hello negative values are correct in this fitting process, like the poster above said be sure that R-R is the distribution that fit your case.
About your problem it depends if are the particles beign splitted (breakup) that under some condition should be correct, or if you see an anomaly in their trajectories, unfortunately DPM involves a wide variety of parametres and for sure is not the more famous model of fluent thus is difficult find someone with a sound knowledge of it. Fabio |
Thanks for the reply fabio and daniele
In my case particle dont split it think, its in micro meter range. I have a multiphase(water and air) with mixture model(water+particles). And the fluid flow With k-e(RNG) trubulence. http://imageshack.us/photo/my-images...jetstream.jpg/ I think im making a mistake in patching(volume fraction). I tried everything still cant solve this problem. If you can give me any advice it will be great. |
Hello, thinkihg about your problem, i would check the forces acting on your particles, modeling a spray in the proper way is quite chellenging.
Forces due to secondary effects (like temperature gradients for example) are negligible or not in correlation with the velocity magnitude and also the size of your particle and thus disturbing the trajectories of your particles. |
