June 22, 2012, 00:10 |
Heat Transfer
shoeb khan
Rep Power: 14 |
Helllo Folks!!!
I have a simple problem but i am not been able to track it properly. Two fluids are mixing 1 hot at 250 C and the other cold at 180 C. (Multi-phase model) I want to have heat transfer between the fluids. Just switching on the energy equation is not favoring the heat transfer. So i decided to use Renz-Marshal as the heat transfer mechanism in this . But the Nussult number calculated by Renz-Marshal law is not for such problems. So anyone tell me how can i calculate the Heat transfer from fluid to fluid region. Thanks Folks for reading it and much more thanks if you provide any small suggestion to me. Regards Shk |
Heat transfer coefficient - what is waht | Stan | FLUENT | 28 | December 29, 2021 16:29 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 18:53 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
