-   -   Weak rotational flow - Convergence Problems (http://www.cfd-online.com/Forums/fluent/64282-weak-rotational-flow-convergence-problems.html)
Daggemann May 6, 2009 02:48
I am simulating seawater flow in a subsea particle filtration unit, with weak to moderate rotating flow induced by stationary curved fins.
I get convergence using all k-epsilon models using SIMPLE pressure.velocity coupling, but when switching to k-omega (standard and SST) the solution only converge for 1st Order Upwind. When switching to higher order schemes the residual oscilliates around a specific point quite far from the convergence criteria of 0.001. It is mainly the continuity residual that struggles.
I have tried under-relaxation and PISO, but they dont do the job.
As inlet condition I have velocity inlet, and the outlet is an outflow. Most of the flow is laminar, but a certain region is turbulent so I figured I had to use turbulent modelling.
Is there any basic steps I can apply in order to figure out the problem, and is it possible that the k-omega turbulence modelling law just doesn't apply in this case?
ty
Ralf Schmidt May 8, 2009 09:45
Hi!
I have no experience with water, but it could be, that there are problems with your grid - see also: http://www.cfd-online.com/Forums/flu...cillation.html
If just some region is turbulent, you might use a "laminar zone" in this regions to suppresses all turbulence (in the fluid BC).
Another option would be, to change the gradient option (-> define -> models -> solver) . I have no idea, what is really behind this settings, but they helped me sometimes...
Hope, that helps a little.
Ralf
