Weak rotational flow - Convergence Problems
Old   May 6, 2009, 02:48
Default Weak rotational flow - Convergence Problems
Dag Stromsvag
Daggemann is on a distinguished road
I am simulating seawater flow in a subsea particle filtration unit, with weak to moderate rotating flow induced by stationary curved fins.
I get convergence using all k-epsilon models using SIMPLE pressure.velocity coupling, but when switching to k-omega (standard and SST) the solution only converge for 1st Order Upwind. When switching to higher order schemes the residual oscilliates around a specific point quite far from the convergence criteria of 0.001. It is mainly the continuity residual that struggles.
I have tried under-relaxation and PISO, but they dont do the job.
As inlet condition I have velocity inlet, and the outlet is an outflow. Most of the flow is laminar, but a certain region is turbulent so I figured I had to use turbulent modelling.
Is there any basic steps I can apply in order to figure out the problem, and is it possible that the k-omega turbulence modelling law just doesn't apply in this case?
ty
Daggemann is offline   Reply With Quote
Old   May 8, 2009, 09:45
Ralf Schmidt
Ralf Schmidt is on a distinguished road
Hi!
I have no experience with water, but it could be, that there are problems with your grid - see also: http://www.cfd-online.com/Forums/flu...cillation.html
If just some region is turbulent, you might use a "laminar zone" in this regions to suppresses all turbulence (in the fluid BC).
Another option would be, to change the gradient option (-> define -> models -> solver) . I have no idea, what is really behind this settings, but they helped me sometimes...
Hope, that helps a little.
Ralf
CFD - nothing but Colourful Fluid Dynamics
Ralf Schmidt is offline   Reply With Quote
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
convergence problems using SBF=1 Fonzie CFX 1 March 23, 2007 08:46
Convergence problems with SSG turbulence model Ram CFX 1 June 19, 2006 10:08
Convergence problems Emilien FLUENT 3 May 3, 2002 08:43
convergence problems david aquilina Siemens 4 October 27, 2000 09:18
