May 11, 2009, 16:59 |
not sure my boundaires are working correctly
Matthew
Rep Power: 17 |
I'm simulating flow over an aircraft probe. Here is an image of the domain and the problem:
This is a laminar, noncompressible run. For this simulation I'm trying to see how the angle of attack changes the flow over the probe. To do this, I have the side boundaires (+/- y) set as symmetry, the top and back (+z,+x) set as outflow and the front and bottom (-x,-z) set as velocity inlet. I then set the x and z component velocities to match my desired velocity vector. In this case it's 225 m/s at 5 degrees (upward). I initialized the model and the vector field looked the way it should. Once I iterated it, I checked my results and they looked funny. The iso surface in the above image is static pressure. It looks like the outflow plane is restricting the flow, causing that uniform bubble of high pressure to form. That symmetry along the y axis just doesn't look right to me. Any thoughts on what is causing this problem? Could it be boundary condition related? grid related? |
May 13, 2009, 16:28 |
I think it depends on the simmetry condition on +/- y. Not allowing mass flux normal to these faces forces the flow in a non physical way.
You should provide some contours on transverse and longitudinal planes to have a deeper insight |
Working Principle of Micro-Oven | aero | Siemens | 2 | January 31, 2007 05:00 |
Help required on working of Micro-oven | aero | CFX | 4 | January 19, 2007 08:21 |
Help required on working of Woven | aero | FLUENT | 0 | January 16, 2007 06:25 |
Need a working supersonic-calculation | Gernot | FLUENT | 1 | March 18, 2006 08:51 |
Error: Unable to retrieve mon from working directo | Atit Koonsrisuk | CFX | 6 | February 20, 2004 05:07 |
