May 16, 2009, 13:39 |
Initial values of K-Epsilon.
Manish
Rep Power: 17 |
I am doing with a 3-d turbulent unsteady air-hydrogen mixing flow in a closed vessel with energy equation off using a volume weighted density performance. I am using K-epsilon model with turbulent length scale as 7% of hydraulic dia. instead i want to use k & Epsilon values. how can I calculate it.
June 1, 2009, 22:33 |
Manish
Rep Power: 17 |
Anybody.........
help me out......... |
June 3, 2009, 07:23 |
how to calculate k & epsilon values
amira maizi
Rep Power: 17 |
k=10^{-3}*v^{2}_{0}
\epsilon= \frac{k^{3/2}}{0.5*d} d is the hydraulic diameter of the face boundary [IMG]file:///C:/DOCUME%7E1/douba/LOCALS%7E1/Temp/msohtmlclip1/01/clip_image002.gif[/IMG] [IMG]file:///C:/DOCUME%7E1/douba/LOCALS%7E1/Temp/msohtmlclip1/01/clip_image002.gif[/IMG] |
June 3, 2009, 09:48 |
Manish
Rep Power: 17 |
thanks, the problem I was facing was due to low inlet velocity model overpridicted turbulence and hence diffusio, now I have tried with K/100 and epsilon/100 values. results hv improved.
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 16 | March 4, 2017 08:30 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 1 | November 25, 2008 20:21 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
Unknown error | sivakumar | OpenFOAM Pre-Processing | 9 | September 9, 2008 12:53 |
