lift coefficent of ahmed body
Old   April 8, 2009, 03:50
Unhappy lift coefficent of ahmed body
simo
unisimo is on a distinguished road
hi,i am using fluent to do external air flow analysis around the ahmed body at 60m/s. the drag coefficent(0.28) is closed to the experiment result(0.285 for slant 25degree),but the lift coefficent(0.001) is far smaller than the experiment result(0.4). I have used several models, unfortunately, there is no improvement on lift coefficient.I have do these in CFX with the same mesh. the Cl is close to the experiment result, but it fluctuate from 0.2 to 0.7
please give me some suggestions
simo
unisimo is offline   Reply With Quote
Old   May 14, 2009, 17:48
Hertzel is on a distinguished road
hi,
could you give some more details about the mesh you used?
how fine it is in the region directly around the body and further away?
how do the velocity plots on some lines behind the body (and on the slant surface) match the ones from the literature or simulations by Lienhart?
(the data of Lienhart's velocity plots can be found easily on the internet)
Greetings
Hertzel
Hertzel is offline   Reply With Quote
Old   May 15, 2009, 04:11
Ralf Schmidt
Ralf Schmidt is on a distinguished road
do you model in 2D? Then, you have to set the area in the reference values panel to the are that that is needed for lift coefficient calculation....
CFD - nothing but Colourful Fluid Dynamics
Ralf Schmidt is offline   Reply With Quote
Old   May 18, 2009, 13:30
Shamoon Jamshed
Shamoon Jamshed is on a distinguished road
Send a message via Skype™ to Shamoon Jamshed
Well the mesh is structures. All the results, vel profile, stream lines are correct. The only problem is the area. In 2D I dont know how to specify the area for each individual wall!
Fluent manual didnot help
Shamoon Jamshed is offline   Reply With Quote
Can't get good results on ahmed body research Michael Main CFD Forum 8 September 17, 2008 13:55
please lol Ahmed Body benzamia FLUENT 0 February 27, 2007 14:08
AHMED BODY (LARGE EDDY SIMULATION) Benzamia FLUENT 0 February 26, 2007 04:59
aerodynamic of Ahmed body VORTEX FLUENT 1 August 7, 2006 20:48
UDF for lift force on a bluff body sawa FLUENT 2 April 11, 2005 03:06
