Home > Forums > FLUENT
heat conduction boundary conditions
Old   June 1, 2009, 02:08
Default heat conduction boundary conditions
sivaraja is on a distinguished road
Dear Friends
I am doing an fluid analysis with heat transfer. the brief description is Aluminium blocks (100 Nos-3D dense block,not a hollw one )on the flat platform available at 45 degrees celcius.Fluid (air) flow over this blocks at at 10 degrees. since the block and fluid are of different volume wall shadow is forming .I need to set the BC so that the heat conduction inside the AL block also to be incorporated.Heat from the flat terrain conducted at the bottom face of the Al block.It is conducted inside the Al block and towards the pheriphery of the block the convection takes place.
I have tried this shell conduction BCs .but the result is not a correct .
Is it really possible in Fluent to solve this problem??
sivaraja is offline   Reply With Quote
Old   June 13, 2009, 04:40
Default heat transfer problem
iggor strato
iggor is on a distinguished road
I'm in the same situation, have you found a solution ?
iggor is offline   Reply With Quote
Thread Tools
Trackbacks are On
free slip boundary conditions Yang Main CFD Forum 8 May 22, 2011 22:14
Water vapour condensation in CFX-5.7.1 hdj CFX 1 November 27, 2005 08:15
Heat conduction through solid rib in periodic duct Dieter Fauconnier FLUENT 0 October 7, 2004 08:22
Copying boundary conditions from model to model Lior FLUENT 3 September 23, 2004 16:10
Boundary Conditions Jan Ramboer Main CFD Forum 11 August 16, 1999 08:59
