3D flow in a pipe
Old   June 2, 2009, 09:23
Default 3D flow in a pipe
Ravi Kapoor
ravi1650 is on a distinguished road
I want to analyse velocity profile of fully developed(laminar) single phase flow in a pipe. For that I have created a pipe in GAMBIT and exported in Fluent with the inlet and outlet conditions as pressure conditions. We know the analytical solution in a pipe and it shud be parabolic at the outlet(when flow is fully developed)
When I am working with low reynold's number, the results are pretty much accurate(RMS error=1.5%) but when I work with high Re # like 1000, I get an error of around 20%. For example, for Re=500, the entrance length required is 3m (D=0.1), so I am woking on L=8m so that fluid is fully developed at the outlet and I have accurate results bt still I am getting error for high Re#. The error increasses as Re# increases.
Moreover, Can I create different interval spacing in axial direction and on the surface nodes in GAMBIT. Like, I have dia=0.1 and L=8m, so if I use Interval count of 60, then it will be fine for the face while coarser for the axial direction whreas if I use interval size of 0.001, it will be okay for the face but too much fine for the axial direction. So, Please help.
Thanks
ravi1650 is offline   Reply With Quote
3d geometry, laminar, pipe, single phase
Simulating fully developed flow in a pipe Tim Donohue CFX 1 November 20, 2007 20:24
some weird results about a simple pipe flow: Ning FLUENT 2 March 11, 2007 13:23
Flow in a Pipe having protrusion inside it Hari Analakkat Main CFD Forum 0 January 25, 2006 06:22
Flow through circular curved stationary pipe R.Sripriya Main CFD Forum 0 May 13, 2005 06:07
Pipe flow John Grimm Main CFD Forum 8 March 11, 2002 12:15
