Cd Cl coefficient
Old   June 3, 2009, 22:39
Default Cd Cl coefficient
Jane
Jane is on a distinguished road
Hai, wanna ask actually how to get Cd and Cl coefficient? Is it using reference value compute from inlet? or is it have another way? is it right using cd and cl value when iteration converge?Coz if use reference value method, my Cl and Cd extremely small.
Thx
Jane is offline   Reply With Quote
Old   June 4, 2009, 02:32
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Coefficients are computed with Reference Values, which you have to set up in Report/Reference Values.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   June 4, 2009, 03:35
Jane
In reference values, what i should put for area? For my case is to simulate flow passing an airplane, then in order to calculate Cd and Cl, what area I should put in?
How about the length?
Thx
Old   June 4, 2009, 05:37
-mAx-'s Avatar
Maxime Perelli
They are typicall values from the body you are computing the force.
The values won't affect the force results.
check the definition of Cd and Cl
Heat transfer coefficient - what is waht Stan FLUENT 28 December 29, 2021 16:29
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 08:43
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
Species diffusion coefficient iceabc FLUENT 1 June 10, 2004 10:04
