-   -   Bug: Surface Integral->Sum w/cut plane and x-face-area (http://www.cfd-online.com/Forums/fluent/65245-bug-surface-integral-sum-w-cut-plane-x-face-area.html)
agodfrey June 9, 2009 13:11
An FYI,
Given:
A custom field function: d-area = abs(x_face_area)
Reports: Surface Integrals
Report Type: Sum
Field Variable: Custom field functions
darea (defined as abs(x-face-area) )
Surfaces: A defined constant-x plane cut through the domain
Yields: Zero erroneously
Other information:
Writing the data shows that each face equals zero to machine precision.
Report Type: Area yields the correct (non-zero) area.
Report Type: Integral w/Custom Fields Function unity (defined as 1) also yields the correct area.
Report Type: Sum on a boundary surface yields the correct area.
Conclusion: Using Sum with a custom field function which needs x-area-face on a defined surface yields erroneous results. Use Report Type: Integral instead.
Note: the integrand of interest is actually (rho * Vx ^ 2 * d-area)
