June 18, 2009, 05:24 |
y+ values!!
Chris Turner
Rep Power: 16 |
I am currently modelling a diffusing cone under steady flow conditions (eventually the model will be under transient flow conditions, but I am using steady flow at the minute to get a better understanding of Fluent). The y+ values on the wall of the diffuser have a very large range when plotted, the minimum is 28 and the maximum is 834! I'm not sure if this is anywhere near normal? There is a lot of turbulentce in the diffuser, with a large annular votrex forming. Also, I have used a cooper mesh, which means the cell size actually increases as the diffusers cross sectional area increases, could this be what is causing the variance in y+ value? Any help would be great! Thanks in advance |
June 18, 2009, 07:55 |
Rep Power: 16 |
you can adapt the mesh in fluent basing on y+ value
Just go to Adapt->Iso-region basically you want to have the y+ value around 5-30 depending on the model you use |
June 18, 2009, 10:55 |
Max
Rep Power: 17 |
Just a comment on pioteks post.
using standard wall functions, y+ should be above 30 larger values up to some limit are acceptable! Thus the grid of Chris is not so bad, a refinement of boundary layers should be restricted to values of y+ > ~200 and only necessary, if these values are found in regions of interest = prostcessing. cheers |
TimeVaryingMappedFixedValue | irishdave | OpenFOAM Running, Solving & CFD | 32 | June 16, 2021 06:55 |
Ensight - node values -cell values | leo | FLUENT | 1 | May 12, 2010 08:47 |
strange node values @ solid/fluid interface - help | JB | FLUENT | 2 | November 1, 2008 12:04 |
node values or cell values? | aPpA | FLUENT | 0 | November 10, 2006 08:56 |
Plotting raw data values | Wilesco | Siemens | 0 | January 5, 2006 05:34 |
