June 17, 2009, 12:35 |
Wake Region Very Long
DT
Rep Power: 16 |
Hi everyone!
This is the link to the velocity profile which I get for the analysis of flow around a vehicle (using FLUENT) after the solution has converged. http://picasaweb.google.com/lh/photo...eat=directlink As you can see, the wake region is very long..is this normal? And also, do you think I should use a longer flow domain? The resistance that I am getting for this vehicle(0.72 m in length and 0.8 sq-m surface area) is approx 4.5 Newtons. Now is that normal? Or is it too low? This vehicle is fully submerged and hence only viscous drag. The Cd calculated by ITTC line (can I use it?) comes out to be pretty low too. The Re is 2.2e+05. Am I doing it correctly? OR do you think that the drag (or the drag coefficient) is too low? Please please help me out. Also, please have a look at this thread: http://www.cfd-online.com/Forums/flu...efficient.html Thank you. |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 11:48 |
Rotating region of a centr. pump - Counter R wall | Emre | CFX | 0 | September 20, 2007 09:58 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
RANS model for near wake region | frederic felten | Main CFD Forum | 0 | April 10, 2003 17:24 |
