Home > Forums > FLUENT
fluent - tecplot problem
Old   June 19, 2009, 04:40
Default fluent - tecplot problem
R. Roy
rr123 is on a distinguished road
dear all,
I have a strange problem.
I cannot activate the Tecplot in export window when I use File Export.
The Tecplot seems to remain deactivated !
Its a 3d double precisison case.
Why is this so ? With other cases files, I do not have this problem and can export easily.
Can someone please help ?
Thanking you.
rr123 is offline   Reply With Quote
Old   June 22, 2009, 10:53
R. Roy
well, i got the answer and posting it here.
Tecplot cannot process for polyhedral or mixed cells (which was my case). so in that you have to rely on other softwares.
this is mentioned in the User guide of Fluent.
Old   June 22, 2009, 15:32
Jim Carson
jim_carson is on a distinguished road
Tecplot cannot process for polyhedral or mixed cells (which was my case). so in that you have to rely on other softwares. this is mentioned in the User guide of Fluent.
Fluent's Tecplot export capabilities haven't been updated in several years. Have you tried using Tecplot's native Fluent loader - versions since Tecplot 360 2008 support n-faced polyhedra.
jim_carson is offline   Reply With Quote
Old   June 22, 2009, 16:30
R. Roy
hi jim,
i have Tecplot 360 2008. can u make some printscreen of what u r saying & attch it with your reply ? then i will give a try...
thanks very much for your reply.
Old   June 22, 2009, 17:28
Jim Carson
Sure. First, select the File -> Load -> Fluent data loader:
Select your files:
Do some plotting stuff:
By the way, in the Tecplot installation directory under ?/doc/tecplot/tpgs.pdf is a tutorial using a Fluent crutcher example. (In the one above, I used a polyhedral dataset to show you the mesh.) The layout for the tutorial is in ?/tutorials/internal_flow/internal_flow.lay.
Thread Tools
Trackbacks are On
Problem Exporting to Tecplot Craig FLUENT 2 July 15, 2008 23:21
Problem about Fluent on Linux hbinma FLUENT 3 July 6, 2008 10:49
UDF problem caused by various version of Fluent Yurong FLUENT 3 January 15, 2006 11:57
Fluent - license problem. Marcin FLUENT 1 March 4, 2005 12:41
Can FLUENT solve this type of problem? Whitaker FLUENT 3 October 23, 2000 03:01
