heat flux in a solid slab
I have solid square slab of 12mmX 12mmX 200um. i have to divide it into four sub-volumes of equal volumes and then assign a different heat flux value to each one of them.I made the udf to do this .I can interpret and initialize it but but when i iterate, I receive following error
chip-exec: heat_flux1: wrong return type: float udf function expectedchip-exec: heat_flux1: argument 1: incorrect type (36): int expected Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: () My udf is as follows: #include "udf.h" DEFINE_INIT(heat_flux1,d) { real x[ND_ND]; real a; cell_t c; Thread *t; thread_loop_c(t,d) begin_c_loop(c,t) { C_CENTROID(x,c,t); if( x[0]<=0.006) { if (x[2]<=0.006) a= 1e9; else a= 5e8; } else { if (x[2]<=0.006) a = 3e8; else a = 9e8; } C_T(c,t)=a; } end_c_loop(c,t) } Please, someone help me out Thanks in advance |
i am working on this problem since 2 days and still couldn't figure out what is going wrong. Please , help me.
thanks |
