-   -   UDF problem: incorrect grid motion (http://www.cfd-online.com/Forums/fluent/65698-udf-problem-incorrect-grid-motion.html)
Fil June 23, 2009 13:02
Hi, I seem to be getting this error message when I'm using this UDF to govern the valve motion in my check valve arrangement. The error happens when I'm setting up dynamic mesh zone for my walls to move through my mesh.
Warning: incorrect grid motion UDF valve::libudf on zone 6 (assuming no motion)
The UDF I'm using is below, any help as to figuring out how I am getting this error would be greatly appreciated.
# include "udf.h"
# include "dynamesh_tools.h"
# ifndef intloop
# define intloop(n,m)for(n=0;n<m;++n)
# endif
/* DEBUG: will print out debug information.
NO_OF_VALVES: Number of valves
NO_OF_ZONES: a large number which is larger than the max number of face
zones per valve
valveid[NO_OF_VALVES][NO_OF_ZONES]={{22, 23, -1}, {13, 14, -1}}: valve face
zone list, in this example, invalve consists of face zone 21 and 23,
exvalve consists of face zone 13 and 14. -1 is a flag and so keep it.
These face zones will be used to calculate the pressure force.
axis[NO_OF_VALVES][ND_ND]={{0, 0, 1}, {0, 0, -1}}: valve motion axis. It points
from the max lift to min lift. And it has to be normalized.
r_rp_closed[NO_OF_VALVES][ND_ND]={{-0.025, 0, 0}, {0.025, 0, 0.005}}: The
reference point coordinates when valves are closed. A reference point,
used to keep track of valve motion, is a point in the valve. The
loation in the valve is immaterial and you can conveniently choose
the location.
lift_min[NO_OF_VALVES]={0.0005, 0.0005}: minimum lift
lift_max[NO_OF_VALVES]={0.01, 0.006}: maximum lift
rest_conts[NO_OF_VALVES]={0.5, 0.5}: bouncing factor
mass[NO_OF_VALVES]={0.02, 0.02}: valve mass
stiffness[NO_OF_VALVES]={2000, 5000}: valve stiffness
stretch_at_closed[NO_OF_VALVES]={0.002, 0.004}: what is the valve stretching
length when the valves are closed
gravity_direction: Gravitational direction. Has to be normalized.
current_vel_mag[NO_OF_VALVES]: Initial velocity. Could be negative if opposite
to valve axis
cur_r_rp[NO_OF_VALVES][ND_ND]: Initial position */
/*************************** User Input Starts *****************************/
# define DEBUG
# define NO_OF_VALVES 1
# define NO_OF_ZONES 200
static int valveid[NO_OF_VALVES][NO_OF_ZONES]={{6 -1}};
static real axis[NO_OF_VALVES][ND_ND]={{0,0,1}}; /* normalized */
static real r_rp_closed[NO_OF_VALVES][ND_ND]={{0.02475, -0.02475, 0.0135}};
static real lift_min[NO_OF_VALVES]={0};
static real lift_max[NO_OF_VALVES]={0.001975};
static real rest_conts[NO_OF_VALVES]={0};
static real mass[NO_OF_VALVES]={0.000817};
static real stiffness[NO_OF_VALVES]={0};
static real stretch_at_closed[NO_OF_VALVES]={0};
static real gravity_direction[ND_ND]={0, 0, 0}; /* normalized */
static real current_vel_mag[NO_OF_VALVES]={0};
static real cur_r_rp[NO_OF_VALVES][ND_ND]={{0.02475, -0.02475, 0.011525}};
static real previous_time[NO_OF_VALVES]={0};
/*************************** User Input Ends *******************************/
static void f_valve(int valveNo, void *dt, real *cg_vel, real *cg_omega, real time, real dtime)
#if !RP_HOST
real tmp[ND_ND], dv, current_vel[ND_ND], CG[ND_ND], force[3], moment[3], stretch;
real aero_force[ND_ND], aero_force_axis, spring_force, net_force, r_rp_new[NO_OF_VALVES][ND_ND];
int i;
Thread * tf;
Domain * domain;
static real cg_vel_saved[NO_OF_VALVES][ND_ND];
/* Do the calculation if the new time step */
if(fabs(previous_time[valveNo]-time)>0.2*dtime)
/* reset velocities */
NV_S (cg_vel, =, 0.0);
NV_S (cg_omega, =, 0.0);
/* Check to see if there is data */
if (!Data_Valid_P ())
Message0("\n\nNo data->No mesh motion!!!\n\n");
return;
/*Calculate force*/
domain = THREAD_DOMAIN (DT_THREAD ((Dynamic_Thread *)dt));
i=0;
NV_S(aero_force,=,0);
while(valveid[valveNo][i]>=0)
tf=Lookup_Thread(domain, valveid[valveNo][i]);
NV_S (CG, =, 0.0);
Compute_Force_And_Moment (domain, tf, CG, force, moment, FALSE);
NV_V(aero_force,+=,force);
i++;
aero_force_axis=NV_DOT(aero_force, axis[valveNo]);
NV_VV(tmp,=,r_rp_closed[valveNo],-,cur_r_rp[valveNo]);
stretch = (stretch_at_closed[valveNo]+NV_DOT(tmp,axis[valveNo]));
spring_force=stiffness[valveNo]*stretch;
net_force=spring_force+aero_force_axis+9.81*mass[valveNo]*NV_DOT(gravity_direction, axis[valveNo]);
dv=net_force/mass[valveNo]*dtime;
/* Calculate the C.G location and velocity if it does not hit the boundary */
NV_VS(current_vel,=,axis[valveNo],*,current_vel_mag[valveNo]);
NV_VS(tmp,=,current_vel,*,dtime);
NV_VV(r_rp_new[valveNo],=,cur_r_rp[valveNo],+,tmp);
/* Update velocity */
current_vel_mag[valveNo]+=dv;
/* debug info */
#ifdef DEBUG
Message0("\n\n*********************** DEBUG INFO ***************************\n");
Message0("\nvalveNo=%3d\n", valveNo);
Message0("\ncur_r_rp[%d]=(%10.3e, %10.3e, %10.3e)\n",
valveNo, cur_r_rp[valveNo][0], cur_r_rp[valveNo][1], cur_r_rp[valveNo][ND_ND-1]);
Message0("\naero force=(%10.3e, %10.3e, %10.3e)\n",
aero_force[0], aero_force[1], aero_force[ND_ND-1]);
Message0("\n(stretching at closed, stretching, force)=(%10.3e, %10.3e, %10.3e)\n",
stretch_at_closed[valveNo], stretch, spring_force);
Message0("\n(net_force, spring force, aero force)=(%10.3e, %10.3e, %10.3e)\n",
net_force, spring_force, aero_force_axis);
Message0("\nvel(cur)=%11.3e vel(next wo limit)=%11.3e ",
current_vel_mag[valveNo]-dv, current_vel_mag[valveNo]);
#endif
/* if it hits the lift_min boundary then it stays at lift_min*/
NV_VV(tmp,=,r_rp_closed[valveNo],-,r_rp_new[valveNo]);
if(NV_DOT(tmp,axis[valveNo])<(lift_min[valveNo]))
NV_V_VS(r_rp_new[valveNo],=,r_rp_closed[valveNo],-,axis[valveNo],*,lift_min[valveNo]);
current_vel_mag[valveNo]=-rest_conts[valveNo]*fabs(current_vel_mag[valveNo]);
/* if it hits the lift_max boundary then it stays at lift_max*/
if(NV_DOT(tmp,axis[valveNo])>(lift_max[valveNo]))
NV_V_VS(r_rp_new[valveNo],=,r_rp_closed[valveNo],-,axis[valveNo],*,lift_max[valveNo]);
current_vel_mag[valveNo]=rest_conts[valveNo]*fabs(current_vel_mag[valveNo]);
/* set valve velocity */
NV_VV(tmp,=,r_rp_new[valveNo],-,cur_r_rp[valveNo]);
NV_VS(cg_vel,=,tmp,/,dtime);
/* Update location and velocity */
NV_V(cur_r_rp[valveNo],=,r_rp_new[valveNo]);
NV_V(cg_vel_saved[valveNo],=,cg_vel);
previous_time[valveNo]=time;
/* debug info */
#ifdef DEBUG
Message0("vel(next w limit)=%11.3e\n", current_vel_mag[valveNo]);
Message0("\nvelocity(CG)=(%10.3e, %10.3e, %10.3e)\n",
cg_vel[0], cg_vel[1], cg_vel[ND_ND-1]);
Message0("\nr_rp_new[%d]=(%10.3e, %10.3e, %10.3e)\n",
valveNo, r_rp_new[valveNo][0], r_rp_new[valveNo][1], r_rp_new[valveNo][ND_ND-1]);
Message0("\n*********************** DEBUG INFO ***************************\n\n");
#endif
else
NV_V(cg_vel,=,cg_vel_saved[valveNo]);
#endif
node_to_host_real(current_vel_mag, NO_OF_VALVES);
node_to_host_real(cur_r_rp[0], NO_OF_VALVES*ND_ND);
node_to_host_real(previous_time, NO_OF_VALVES);
DEFINE_CG_MOTION(valve, dt, cg_vel, cg_omega, time, dtime)
f_valve(0, dt, cg_vel, cg_omega, time, dtime);
node_to_host_real(cg_vel,ND_ND);
node_to_host_real(cg_omega,ND_ND);
DEFINE_EXECUTE_AT_END(output_results)
#if !RP_HOST
int i;
FILE *fp_results;
#if PARALLEL
if(I_AM_NODE_ZERO_P)
#endif
if(!(fp_results=fopen("results.txt","a")))
Message0("\nCan not open file-aborting!!");
exit(0);
#if PARALLEL
#endif
fprintf(fp_results, "%12.4e ", CURRENT_TIME);
for(i=0; i<NO_OF_VALVES; i++)
fprintf(fp_results, "%12.4e ", NV_DOT(cur_r_rp[i],axis[i]));
fprintf(fp_results, "\n");
fclose(fp_results);
#endif
static void write_data(FILE *fp)
int i, j;
fprintf(fp, "%e ", current_vel_mag[i]);
fprintf(fp, "\n");
for(j=0; j<ND_ND; j++)
fprintf(fp, "%e ", cur_r_rp[i][j]);
fprintf(fp, "\n");
fprintf(fp, "\n");
fprintf(fp, "%e ", previous_time[i]);
DEFINE_RW_FILE(writer, fp)
Message0("Writing UDF data to data file...\n");
#if PARALLEL
#if RP_HOST
write_data(fp);
#endif
#else
write_data(fp);
#endif
static void read_data(FILE * fp)
int i, j;
fscanf(fp, "%e", current_vel_mag+i);
fscanf(fp, "%e", cur_r_rp[i]+j);
fscanf(fp, "%e", previous_time+i);
DEFINE_RW_FILE(reader, fp)
Message0("Reading UDF data from data file...\n");
#if PARALLEL
#if RP_HOST
read_data(fp);
#endif
#else
read_data(fp);
#endif
host_to_node_real(current_vel_mag, NO_OF_VALVES);
host_to_node_real(cur_r_rp[0], NO_OF_VALVES*ND_ND);
host_to_node_real(previous_time, NO_OF_VALVES);
Thanks a lot in advance.
erkan June 23, 2009 16:14
It is not a familiar topic for me but I have a question, did you move the case&data file anywhere else than where you compiled the UDF ?
-mAx- June 24, 2009 01:39
you have to use this udf for completing the rigid body motion of your body
gi12 January 7, 2011 18:30
Hi guys
I have posted this question in many places of the forum, perhaps one of you might help me and I would really appreciate it. I need to simulate a compliant wall of say a simple pipe. I do have the elasticity and the maximum displacement also. Can you please help me whit a UDF instructions this valve program is unclear and not applicable to my case. Your help is very much appreciated
Many thanks
renatovj January 3, 2015 14:14
# include "udf.h"
# ifndef intloop
# endif
zones per valve
the location.
to valve axis
# define DEBUG
#if !RP_HOST
int i;
Thread * tf;
Domain * domain;
return;
/*Calculate force*/
i=0;
NV_S (CG, =, 0.0);
i++;
/* debug info */
#ifdef DEBUG
#endif
/* debug info */
#ifdef DEBUG
#endif
else
#endif
#if !RP_HOST
int i;
FILE *fp_results;
#if PARALLEL
#endif
exit(0);
#if PARALLEL
#endif
fclose(fp_results);
#endif
int i, j;
fprintf(fp, "\n");
fprintf(fp, "\n");
fprintf(fp, "\n");
#if PARALLEL
#if RP_HOST
write_data(fp);
#endif
#else
write_data(fp);
#endif
int i, j;
#if PARALLEL
#if RP_HOST
read_data(fp);
#endif
#else
read_data(fp);
#endif
Dear Gi,
Have you solved this problem yet?
I'm facing the same problem. I'd appreciate your help!
