June 25, 2009, 15:13 |
Fluent Runtime After Adaption
Rep Power: 16 |
Wondering what others experience is with running Fluent and hanging-node adaption.
I have a case with 50 million finite volumes that takes X sec/iteration. I adapted and have 65 million finite volumes and it now takes 4X sec/iteration. I would expect less, but any other experiences would be useful. Thanks Scott N |
June 25, 2009, 15:32 |
HP Kritzinger
Rep Power: 16 |
hi scott
i presume you are running a distributed parallel run? (or you have very nice SMP hardware...) what i have seen is that the adapted mesh sometimes tend to stay on the partition where it was generated. You will start seeing unequal loads on the parallel cores - in effect you might have a few of your cores which now has 4 times as many cells to compute. you can either manually repartition in Fluent, or try activating the load balancing for parallel runs. just a thought... |
Stopping a Fluent batch job AND saving the data! Possible? | Volker Pawlik | FLUENT | 13 | December 28, 2020 04:16 |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
Integration of a Custom C++ Model into FLUENT | Syed Haider | FLUENT | 2 | March 6, 2018 23:37 |
FLUENT to ANSYS Temperature Mapping Procedure | schreiberc1 | FLUENT | 0 | June 29, 2006 13:50 |
Run Fluent in batch mode | Shengping LUO | FLUENT | 2 | October 24, 2000 05:42 |
