July 1, 2009, 05:57 |
Porous Formulation
Hello!
I am modelling a heterogeneous porous zone and I am only interested on the velocity profile and pressure drop. I included the inertial and viscous resistance coefficients in the Porous Zone Panel. Do I also need to include the porosity? I suppose that the momentum sink produced by a porous region is completely depicted by resistance coefficients, right? Where is the difference if I include porosity values? Thank you for your time! |
July 1, 2009, 07:20 |
Flow in porous media can be calculated using either a model for momentum loss or a full porous model. The momentum loss model is useful for modeling porous resistances without taking the volume effect of porosity into account. If you need to account for the volume effect, use the porosity. The velocity solved by the code is usually the superficial fluid velocity. In a porous region, the true fluid velocity of the fluid will be larger because of the flow volume reduction. Sometimes a loss model is formulated in terms of true velocity rather than superficial velocity. |
Porous Formulation in Aerodynamic computation | F.B. | FLUENT | 1 | May 13, 2008 17:40 |
Testing the integrity of POROUS media and por jump | Azman | FLUENT | 0 | July 31, 2006 11:11 |
physical velocity formulation and porous media | KLG | FLUENT | 2 | June 10, 2003 10:14 |
porous media: Fluent or Star-CD? | Igor | Main CFD Forum | 0 | December 5, 2002 15:16 |
porous body formulation | K. Natesan | Siemens | 0 | November 22, 2002 03:29 |
