Regarding about Fluent batch scripts
I am using PBS to subscrib the job to clusters for fluent cases. But there are always some error feed back I cannot slove. Is there any one who can help me take a look at it? Thanks a lot!
1. Fluent script: rc /data/l/users/u0062648/testcase/vf_rng/vf_rng.cas solve/initialize/init-flow-statistics solve/iterate 50 wd /data/l/users/u0062648/testcase/vf_rng/vf_rng50.dat exit yes 2. This is the feed back! Thanks a lot! invalid command [init-flow-statistics^M] > Error: eval: unbound variable Error Object: 50^M solve/iterate 50^M Invalid integer. Number of iterations [1] Error: eval: unbound variable Error Object: wd wd Invalid integer. Error: eval: unbound variable Error Object: /data/l/users/u0062648/testcase/vf_rng/vf_rng50.dat^M /data/l/users/u0062648/testcase/vf_rng/vf_rng50.dat^M Invalid integer. Number of iterations [1] Error: eval: unbound variable Error Object: exit^M exit^M Invalid integer. Number of iterations [1] Error: eval: unbound variable Error Object: yes^M yes^M Invalid integer. |
Did you create your journal file on a Windows machine? If so, it may have included line break characters at the end of each line which the Linux/Unix cluster does not like. Try creating the file either on a Linux system or save in Notepad/Wordpad using 'unicode' formatting.
See http://kb.iu.edu/data/acux.html for more info. |
thanks a lot! you are absolutely right! problem solved
You're welcome - glad to help.
