Reg:Multiple UDFs
i am Roma, i am working on a problem in Fluent which involves me to use a couple of UDF functions.These are basically varying temperature with position. My polynomial for the upper wall temperature is different from the lower one. So i have two different .c files.When i hook these two into Fluent,i cannot see both the udf functions in the drop down menu. In my UDF code i have exactly the same arguments,except that the profile is changing. How should i proceed on this? Thank You |
you can only adopt one udf so every subroutine should be written in it (with different names!)
Two solutions: an if/else cycle or change the variable names |
