July 6, 2009, 14:29 |
K-OMEGA for flow in branches?
afm
Rep Power: 16 |
hello;
i'm trying to find the best turbulence model in FLUENT to be used for flow in branches and manifolds. using some data i found that standars and SST K-OMEGA is the best. is this ok? as i understand, k-w is only used for heat transfer applications. So, is it ok to use it for flow in branches? thank you |
July 7, 2009, 05:51 |
Rep Power: 17 |
Menters SST model giving nice solution in adverse pressure gradient flows. I think in your situation it is the best 2-eqn model. I strongly recommend you to take a look at Menters article on AIAA Journal Vol. 32 No.8
Moreover SST model is largely being used in aerodynamic applications that includes massive seperation, such as oscillating airfoil etc.
Timeo hominem unius libri |
Display Modes | |
Specific Dissipation Rate (Omega) | Lourival | FLUENT | 2 | July 25, 2010 08:59 |
K-omega for flow in branches? | cfdlover | Main CFD Forum | 1 | July 6, 2009 21:35 |
Airfoil with k Omega | hoochie | OpenFOAM Running, Solving & CFD | 0 | July 3, 2007 08:10 |
RSM Low-Re Stress Omega | John | FLUENT | 0 | June 13, 2007 13:27 |
Defining deformable mesh UDF to set omega | Chris | FLUENT | 0 | August 30, 2006 16:01 |
