open channel problem (free surface)
Dear experts :
I simulated open channel. I have some question. Please experts help me. And my following: fluent 3dp file ® read case . grid ® check. define ® models ® solver ® time(steady)®ok. define ® models ® multiphase ® volume of fluid ® open channel flow ® ok ® implicit body force ® ok. define ® models ® energy ® not selected ® ok. define ® models ® viscous ® k – epsilon model ® RNG® standard wall function ® ok . define ® materials ® water liquid ® copy ® create. Define ® phases ® phase 1 ® air, phase 2 ® water liquid ® close. Define ® operation conditions ® gravity ® X coordinate 0.017 ®Z coordinate -9.81 ® specified operation density selected ® ok. Define ® boundary conditions ® inflow ® mass-flow-inlet ® phase mixture ® open channel ® Free surface level 0.25 (m) ® bottom level 0.0 (m) ®k and epsilon ® ok. Define ® boundary conditions ® outflow ® outflow ® phase mixture ® flow rate weighting 1.0 ®ok. Define ® boundary conditions ® wall (left, bottom, right boundary ) ® wall ® momentum ® roughness height 0.02 ® roughness constant 0.5 ® ok. Define ® boundary conditions ® top boundary ® symmetry ® ok. Solve ® controls ® solutions ® piso algorithm ® pressure body force weighted ® ok. Solve ® initialize ® compute from ® inflow ® lint ® close. Solve ® initialize ® patch ® volume fraction ® value 1 ® patch. Solve ® monitors ® residual ® plot select ® ok. Solve ® iterate . My inflow free surface level is 0.25 m, and my dike is 0.4 m. When I iterate over that my water depth is 0.4 m, isn't 0.25 m. It's so strange. I use VOF model, but my result didn't have free surface. Please experts help me. It's big problem for me. Thanks your help. |
"Define ® boundary conditions ® top boundary ® symmetry ® ok."
Is this right for free surface problem? |
Very thanks your help, John. |
Please, could anyone help me?
I really want to experts solve my problem. It's really a big problem for me. So, please help me! |
It's hard to simulate open channel in Flunet.
Extend your two side boundaries to the height which free surface may be. And combined the top boudnary to form a upside down U shape boundary. Then set it to : pressure inlet When you use symmetry, it assume no flux across. If the free surface is higher than that, it can't cross the top lid. This may solve it and btw use 2d first to test it. If you suceed, tell us how you have done it. |
