open channel problem (free surface)
Old   July 9, 2009, 03:04
Default open channel problem (free surface)
Yi-Lang Chen
Andy Chen is on a distinguished road
Dear experts :
I simulated open channel. I have some question. Please experts help me. And my following:
fluent 3dp
file
® read case .
grid ® check.
define ® models ® solver ® time(steady)®ok.
define ® models ® multiphase ® volume of fluid ® open channel flow ® ok ® implicit body force ® ok.
define ® models ® energy ® not selected ® ok.
define ® models ® viscous ® k – epsilon model ® RNG® standard wall function ® ok .
define ® materials ® water liquid ® copy ® create.
Define ® phases ® phase 1 ® air, phase 2 ® water liquid ® close.
Define ® operation conditions ® gravity ® X coordinate 0.017 ®Z coordinate -9.81 ® specified operation density selected ® ok.
Define ® boundary conditions ® inflow ® mass-flow-inlet ® phase mixture ® open channel ® Free surface level 0.25 (m) ® bottom level 0.0 (m) ®k and epsilon ® ok.
Define ® boundary conditions ® outflow ® outflow ® phase mixture ® flow rate weighting 1.0 ®ok.
Define ® boundary conditions ® wall (left, bottom, right boundary ) ® wall ® momentum ® roughness height 0.02 ® roughness constant 0.5 ® ok.
Define ® boundary conditions ® top boundary ® symmetry ® ok.
Solve ® controls ® solutions ® piso algorithm ® pressure body force weighted ® ok.
Solve ® initialize ® compute from ® inflow ® lint ® close.
Solve ® initialize ® patch ® volume fraction ® value 1 ® patch.
Solve ® monitors ® residual ® plot select ® ok.
Solve ® iterate .
My inflow free surface level is 0.25 m, and my dike is 0.4 m. When I iterate over that my water depth is 0.4 m, isn't 0.25 m. It's so strange. I use VOF model, but my result didn't have free surface. Please experts help me. It's big problem for me.
Thanks your help.
Andy Chen is offline   Reply With Quote
Old   July 9, 2009, 09:16
John is on a distinguished road
"Define ® boundary conditions ® top boundary ® symmetry ® ok."
Is this right for free surface problem?
John is offline   Reply With Quote
Old   July 9, 2009, 09:58
Yi-Lang Chen
Yes, I simulated open channel (free surface ) problem. Did I set wrong on top boundary? Then, how did I set on top boundary ?
Very thanks your help, John.
Old   July 9, 2009, 23:38
Yi-Lang Chen
Please, could anyone help me?
I really want to experts solve my problem.
It's really a big problem for me. So, please help me!
Old   July 10, 2009, 01:20
vovman is on a distinguished road
It's hard to simulate open channel in Flunet.
Extend your two side boundaries to the height which free surface may be.
And combined the top boudnary to form a upside down U shape boundary.
Then set it to : pressure inlet
When you use symmetry, it assume no flux across. If the free surface is higher than that, it can't cross the top lid.
This may solve it and btw use 2d first to test it.
If you suceed, tell us how you have done it.
vovman is offline   Reply With Quote
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
A free surface problem crammer008 OpenFOAM 2 April 27, 2009 21:41
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 06:47
