UDF profile function of iteration
Old   July 9, 2009, 11:19
Unhappy UDF profile function of iteration
nando83 is on a distinguished road
Hi, I'm a newbie with UDF.
I'd like to impose as boundary condition a static pressure value depending on flow properties. (Sorry for my bad english )
I'd like Fluent computes, every iteration, the values of total pressure, total temperature and mass flow rate on a boundary surface and uses this values to compute a value for the static pressure to be imposed on that surface.
Is correct to use DEFINE_PROFILE?How can I change the profile every iteration?
Thank you.
nando83 is offline   Reply With Quote
udf profile bounday
UDF vs Custom field function andrew FLUENT 5 June 24, 2011 10:53
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
UDF: PROFILE + SOURCE Nuno FLUENT 0 September 1, 2008 15:31
OpenFoam 14 installation problem gfcoppola OpenFOAM Installation 20 November 2, 2007 13:38
