July 10, 2009, 13:55 |
Inserting Small bubble particle
christian paul
Hi all,
I need some help with VOF modeling in fluent. We have a 2D Horizontal micro channel that is 5e-05 meters in diameter and 7.5e-04 in length and we have the primary stage set to water and the secondary stage set to a type of oil found in the fluent database. We first ran a simple flow problem with just water. We saved those results and used them when we initiated the Volume of Fluid. Here are our paramters. Solver: pressure based, 2D, absolute formulation, implicit formulation, unsteady time Multiphase: Explicit VOf scheme, implicit body force with two phases. Material: Water-liquid, Gas-oil liquid operating conditions: Left as is, we want to know if we should change this Boundry condition: Inlet velocity 0.001 m/s pressure is 0, should we change this? Solve> controls Equations are flow and volume fraction Pressure velocity coupling- simple pressure: Presto Momentum: first order upwind Volume fraction: geo-reconstruct We would also like to know what the benifit of Patch is, and if it is necessary in our case. The main problem we're having is that the bubbles are the same diameter as the channel, we would like to know if there is any way we can control the amount of oil that goes into the channel so our oil droplet would be roughly 10 microns. Also if there is a way to measure the forces acting on the bubble. thanks Last edited by cpaul; July 13, 2009 at 09:56. |
Particle Trajectory calculation | yueroo | FLUENT | 2 | July 13, 2009 13:32 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
gas hold up in bubble | Shelly | Main CFD Forum | 0 | November 13, 2006 00:28 |
Query on VOF for Bubble rise | Vamsi | Main CFD Forum | 0 | December 22, 2005 00:02 |
the separated particle temperature in cyclone | mkuswadi | FLUENT | 0 | December 17, 2003 08:25 |
