Unable to switch from Rotating Reference Frame to Mixing Plane |
July 10, 2009, 15:56 |
Ben
Hi All,
I am trying to implement a mixing plane between a radial impeller and diffuser passage. I have a solution using a rotating reference frame for the impeller zone, but when I then define a mixing plane (changing the interface boundaries to a pressure outlet and mass-flow inlet) at this interface, FLUENT crashes and gives a number of error messages, including "Stack backtrace generated for node id 3 on signal 11" I am using the pressure based solver, compressible flow w/ k-w SST turbulence model. If anyone has experience with this situation, any advice would be appreciated. Thanks in advance, Ben |
mixing plane |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 01:35 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
G95 + CGNS | Bruno | Main CFD Forum | 1 | January 30, 2007 01:34 |
Building OpenFoAm on SGI Altix 64bits | anne | OpenFOAM Installation | 8 | June 15, 2006 10:27 |
about mutiple rotating reference frame | lingo | FLUENT | 0 | December 12, 2002 05:13 |
