July 14, 2009, 13:55 |
Mean Mixture Fraction
Erik Sellers
I am using the non-premixed combustion model in Fluent and have generated a PDF Table ... It is an uni-element injector with an OFO (oxygen-fuel-oxygen) configuration. I am confused about the inputs for the mean mixture fraction (MMF) in the fuel and oxidizer boundary condition. Right now I have the MMF for fuel set to 1.0 and the oxidizer set to 0; when should these be varied and what is the impact? Also, in my initial conditions, the MMF is set to 0, is this correct? I was also under the impression that the temperature given in the initial values acts as the igniter for combustion, does anyone have any data supporting cryogenic propellants (methane and oxygen) on what this temperature should be set to?
One last thing, how can I define only one reaction using the non-premixed combustion model w/ PDF Table? And am I able to define the mechanism ... specify a two-step reaction? Thank you, your help is very much appreciated! --E |
September 23, 2023, 11:42 |
can
Rep Power: 2 |
MMF = 1 means there is only fuel on that region and MMF = 0 means there is only oxidizer on that region. And after combustion MMF should be zero if you dont have another combustion at downstream. I dont exactly know the other questions that you have written.
chemical mechanism, combustion, mean mixture fraction, methane, oxygen |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 07:22 |
Mixture fraction for combustion problem | Jonathan Lemay | CFX | 3 | November 5, 2007 14:57 |
Mixture Fraction | SanyaKrasnoyarsk | Siemens | 0 | February 1, 2006 04:31 |
mixture fraction | Sheng Chen | Main CFD Forum | 0 | October 6, 2004 01:33 |
