LP-Turbine with Low Reynolds
Old   July 15, 2009, 21:27
Default LP-Turbine with Low Reynolds
kikimon is on a distinguished road
I’m running a 2-D Steady simulation in an LP-turbine. Experimental results under the same conditions show no flow separation, but it should be close (very small Re).
The conversion graphs of my residuals and mass-weighted average Cp at back flow are linear with abrupt periodic spikes. The results during the linear stages of the conversion match with the experiment and the flow is attached. But during the spike stages, shows strong flow separation and therefore don’t match at all the experimental results.
I have used 3 turbulence models, kw, k-kl and Transition SST. I have also varied turbulence inputs and relaxation factors, which seems to only change period of appearance of the spikes.
How do I get it to converge without these sudden spikes? Any idea is very appreciate it.
Thank you very much.
Pablo
kikimon is offline   Reply With Quote
Turbulence model for low Reynolds number flow? Nokadu Main CFD Forum 3 May 26, 2013 11:42
low reynolds number models in Fluent doug Main CFD Forum 6 August 4, 2012 14:39
Low Reynolds Number k-epsilon formulation CFX 10.0 Chris CFX 4 December 7, 2009 23:51
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
How low for low Reynolds model? Jean-Luc Phoenics 3 March 10, 2001 01:34
