Home > Forums > FLUENT
Highly skewed element.
Old   July 16, 2009, 08:34
Post Highly skewed element.
EYITAYO AFOLABI
EYITAYOAFOLABI is on a distinguished road
can some one please explain steps to take in resolving highly skewed element in a mesh?
Thanks for the anticipated assistance.
EYITAYOAFOLABI is offline   Reply With Quote
Old   July 17, 2009, 03:22
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
go back to the mesher, correct some parameters, remesh and check cells quality
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   July 18, 2009, 17:28
Default Highly Skew Mesh
EYITAYO AFOLABI
Can you please mention some of the parameters that needed to be change in order to correct highly skew mesh?
Old   July 18, 2009, 22:26
Farhat Rasool Khan
Farhat is on a distinguished road
May be you are meshing a geometry with complicated surfaces. You should decompose the domain so as to limit skewness to as small area as possible and use structured meshing. Skewness arises when the meshes get deformed near the complicated surfaces.
Farhat
Farhat is offline   Reply With Quote
Old   July 20, 2009, 01:27
-mAx-'s Avatar
Maxime Perelli
Check in the mesher what is the cause of the skewness (typical: small edges, small angles etc...)
Thread Tools
Trackbacks are On
Can highly skewed elements create problem?? Sanjay Jain FLUENT 1 April 8, 2008 15:57
help: the volume mesh has highly skewed elements xiaofish FLUENT 3 September 18, 2007 09:51
what to do w/ highly skewed elements? (GAMBIT) mike FLUENT 5 June 2, 2007 22:10
highly skewed elements srikanth Main CFD Forum 1 February 21, 2006 09:15
Highly skewed elements Hengky FLUENT 2 August 11, 2005 12:17
