Home > Forums > FLUENT
problem of running parallel Fluent on linux cluster
Old   July 22, 2009, 16:33
Default problem of running parallel Fluent on linux cluster
Ivan
ivanbuz is on a distinguished road
the case runs fine if I require several processors on the SAME node, but if the processors are on different nodes, I have the "Connection refused" problem.
I search online and see that some people have the similar problem, but I can not find a solution to this specific problem. the output from Fluent and the submission script are attached below.
Thanks in advance!
OUTPUT FROM FLUENT
/opt/hpc/Fluent.Inc/fluent6.3.26/bin/fluent -r6.3.26 -pib -cnf=/var/spool/PBS/aux//3666504.cmgr01 -g 2ddp -t6 -i test2.jou
/opt/hpc/Fluent.Inc/fluent6.3.26/cortex/lnamd64/cortex.3.7.3 -f fluent -g -i test2.jou (fluent "2ddp -pib -host -r6.3.26 -t6 -mpi=hp -cnf=/var/spool/PBS/aux//3666504.cmgr01 -path/opt/hpc/Fluent.Inc")
Loading "/opt/hpc/Fluent.Inc/fluent6.3.26/lib/fluent.dmp.114-64"
Done.
/opt/hpc/Fluent.Inc/fluent6.3.26/bin/fluent -r6.3.26 2ddp -pib -host -t6 -mpi=hp -cnf=/var/spool/PBS/aux//3666504.cmgr01 -path/opt/hpc/Fluent.Inc -cx scw-029.i:59263:37434
Starting /opt/hpc/Fluent.Inc/fluent6.3.26/lnamd64/2ddp_host/fluent.6.3.26 host -cx scw-029.i:59263:37434 "(list (rpsetvar (QUOTE parallel/function) "fluent 2ddp -node -r6.3.26 -t6 -pib -mpi=hp -cnf=/var/spool/PBS/aux//3666504.cmgr01 ") (rpsetvar (QUOTE parallel/rhost) "") (rpsetvar (QUOTE parallel/ruser) "") (rpsetvar (QUOTE parallel/nprocs_string) "6") (rpsetvar (QUOTE parallel/auto-spawn?) #t) (rpsetvar (QUOTE parallel/trace-level) 0) (rpsetvar (QUOTE parallel/remote-shell) 0) (rpsetvar (QUOTE parallel/path) "/opt/hpc/Fluent.Inc") (rpsetvar (QUOTE parallel/hostsfile) "/var/spool/PBS/aux//3666504.cmgr01") )"
Welcome to Fluent 6.3.26
Copyright 2006 Fluent Inc.
All Rights Reserved
Loading "/opt/hpc/Fluent.Inc/fluent6.3.26/lib/flprim.dmp.1119-64"
Done.
Host spawning Node 0 on machine "scw-029" (unix).
/opt/hpc/Fluent.Inc/fluent6.3.26/bin/fluent -r6.3.26 2ddp -node -t6 -pib -mpi=hp -cnf=/var/spool/PBS/aux//3666504.cmgr01 -mport 192.168.2.129:192.168.2.129:34193:0
Starting /opt/hpc/Fluent.Inc/fluent6.3.26/multiport/mpi/lnamd64/hp/bin/mpirun -prot -vapi -e MPI_HASIC_VAPI=1 -e MPI_USE_MALLOPT_SBRK_PROTECTION=1 -e MPI_USE_MALLOPT_AVOID_MMAP=1 -f /tmp/fluent-appfile.32087
192.168.2.135: Connection refused
mpirun: Warning one more more remote shell commands exited with non-zero status, which may indicate a remote access problem.
SUBMISSION SCRIPT
#!/bin/sh
#PBS -j oe
#PBS -l nodes=2:ppn=3
#PBS -q main
#PBS -l walltime=00:10:00
cd ${PBS_O_WORKDIR}
cat ${PBS_NODEFILE}
#Set variables for script
# What version of the solver to use
FLUENTSOLVER=2ddp
#HOW MANY CPUS- note that you'll still need to update the $PBS -l nodes line
CPUCOUNT=6
#Which input journal file to use to give fluent?
#INPUT=${PBS_O_WORKDIR}/${PBS_JOBNAME}
INPUT=test2.jou
#Where do we want to put output at?
OUTPUT=${PBS_O_WORKDIR}/${PBS_JOBID}.out
# Run Fluent with:
# -pib use Infiniband parallel
# -cnf=$PBS_NODEFILE get the list of machines PBS is running on from the server
# -t$CPUCOUNT use $CPUCOUNT CPUs total
# -g no graphics, batch mode
# -i read the file in $INPUT
# > $OUTPUT 2>&1 Redirect program output to a file in your home directory.
fluent $FLUENTSOLVER -t$CPUCOUNT -pib cnf=$PBS_NODEFILE -g -i $INPUT > $OUTPUT 2>&1
ivanbuz is offline   Reply With Quote
Old   July 23, 2009, 01:32
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Are you able to connect to your nodes with rsh or ssh?
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   July 23, 2009, 03:15
Ivan
yes, I have access to all nodes using SSH
Old   July 23, 2009, 03:44
-mAx-'s Avatar
Maxime Perelli
passwords aren't required?
Old   July 23, 2009, 14:07
Ivan
I log into the cluster before submitting the job. so there should be no problem with password.
Old   July 23, 2009, 14:10
Ivan
If guys from Fluent.INC see this thread, can you take a look?
Old   July 24, 2009, 01:19
-mAx-'s Avatar
Maxime Perelli
I am not an linux expert / fluent-parallel , but you said that you are using SSH.
SSH needs password.
if you try a command on a node, what is the result?
> ssh ip-address ls
Old   July 24, 2009, 15:10
Ivan
Hi, mAx, There is no problem. the output is similar to the following
bushivan@scw-097:~>ssh 192.166.2.195 ls
airfoil
airfoil_ins_eig
default_id.dbs
Old   July 24, 2009, 16:35
-mAx-'s Avatar
Maxime Perelli
Is there an administrator under your Cluster or did you set it yourself?
Old   July 24, 2009, 17:43
Ivan
The cluster is operated by the HPC center. I just submit my job there. I actually talked to people of HPC, and they said something like the MPI used by the clusters is not compatible with Fluent, but I am not sure if they are right. So I just post my problem here and see if anyone has encountered the same problem.
Old   July 25, 2009, 02:15
-mAx-'s Avatar
Maxime Perelli
Then they are the right people to solve your problem.
But it may be sad not being able to use fluent's parallel enhancement with this cluster
Old   March 10, 2010, 16:13
Ibad Kureshi
ibnkureshi is on a distinguished road
i know this is late, but you have to give the '-ssh' in the fluent command line in the submission file. that forces fluent to use ssh rather than rsh which it always goes to by default
ibnkureshi is offline   Reply With Quote
cluster, fluent, parallel
Thread Tools
Trackbacks are On
parallel fluent runs being killed at partitioing Ben Aga FLUENT 3 June 8, 2012 10:40
Running on Distibuted Memory linux itanium cluster Josh FLUENT 0 January 29, 2007 01:18
running multiple Fluent parallel jobs Michael Bo Hansen FLUENT 8 June 7, 2006 08:52
Fluent Parallel for Linux? Rajil Saraswat FLUENT 0 June 11, 2003 10:53
Time problem in parallel fluent MZB FLUENT 1 May 13, 2003 02:37
