Regarding Boundary Condition at Outlet for gas-solid simulation
Old   July 11, 2013, 15:21
Question Regarding Boundary Condition at Outlet for gas-solid simulation
shubham
shubham208011 is on a distinguished road
Hi all,
I have two quarries regarding Boundary Condition at Outlet for solid granular simulation please spare some time to answering them and helping me. The quarries are as follow:
1.) In fluent user guide it is clearly mentioned that outflow boundaries cannot be used in the following cases:
a.) If a problem includes pressure inlet boundaries; use pressure outlet boundary conditions (see Section 7.3.8) instead.
b.) If you are modeling compressible flow.
c.) If you are modeling unsteady flows with varying density, even if the flow is incompressible.
d.) With the multi-phase models (Eulerian, mixture, and VOF (except when modeling open channel flow, as described in this section in the separate Theory Guide).
But, if some used it for modelling multiphase flow (gas-solid flow through a pipe) what will happen?????
2.) If the value of gauge pressure is not known at the outlet only gauge pressure at inlet and velocity for both phase at inlet are known, then what value of gauge pressure for pressure-outlet boundary condition be used for simulation????
Thanks..
shubham208011 is offline   Reply With Quote
Setting Pressure outlet boundary for simulation of Radial impeller Mukund Pondkule Main CFD Forum 1 April 5, 2011 09:24
inlet and outlet boundary condition for turbomachinery solution siamak1424 OpenFOAM 2 August 15, 2009 11:14
Implications for heat transfer when outlet pressure boundary condition used Blob CFX 2 March 26, 2009 06:22
outlet boundary condition Nina Schiepel CFX 2 July 12, 2008 15:27
Outlet boundary condition for pd in InterFoam gopala OpenFOAM Running, Solving & CFD 0 March 19, 2008 09:26
