Porous media : simulation of an heat exchanger
I am simulating the cooling down of the air through an heat exchanger. It has aluminium fins. I need that you validate (or not) my thought. I want to put the right pressure drops in the flow direction (Z) and to forbid the flow in the other direction (becaus of the fins). * viscous resistance = f(1/permeability) -> Z : 0 (no material in this direction) -> X,Y : high value to forbid the flow in this direction * inertial resitance = f(pressure loss per unit lenght along the flow direction) -> Z : the coefficient I've calculated to obtain the good pressure drop -> X,Y : 0 (no friction pressure drop in this direction) What do you think about that? Thank you for each answer. |
someone has any idea?
About the pressure drop, you are right.
The problem is how to treat the heat transfer between the air and the fins. |
in fact, I just calculate the temperature exchanges to have the good density, in the aim of having the good pressure drops in my model. I don't seek to have the real temperature.
I have one inlet an one outlet. I know that I have 155°C in the inlet and I want 50°C in the outlet. So I've calculated the heat exchange (Q=mCdT) in created a energy source in the porous media. |
the pressure drop is dependent on the fluid properties which are dependent on the temperature.
i know. That's why I have implemented a source term. The Temperature depend on the velocity.
I meant that the modelization of the temperature exchanges is sufficient with a source term for me (I don't need to develop an udf to be more precise). |
Hi Arnaud,
please witch Solver are you used? Could you send me your case? I would like to simulate an Heat exchanger too, but it donīt work! Thank you in advance |
