Compile UDF
Old   July 29, 2009, 00:05
Default Compile UDF
Alkulkarni
Alkulkarni is on a distinguished road
Dear All,
I am trying compile UDF from tutorial in Fluent. The error message displayed is as below
Deleted old libudf\win64\2d\libudf.dll
1 file(s) copied.
(system "copy C:\Fluent.Inc\fluent6.3.26\src\makefile_nt.udf libudf\win64\2d\makefile")
1 file(s) copied.
(chdir "libudf")()
(chdir "win64\2d")()
'nmake' is not recognized as an internal or external command,
operable program or batch file.
Does anyone have idea to solve it?
Thank you,
Abhijit Kulkarni
Alkulkarni is offline   Reply With Quote
Old   August 4, 2009, 12:07
Dongzi Wei
Jiuan is on a distinguished road
I had the same problem bofore. When I check the UDF manual, it is noted that we have install microsoft visual studio to compile UDF.
Originally Posted by Alkulkarni View Post
Dear All,
1 file(s) copied.
1 file(s) copied.
(chdir "libudf")()
Thank you,
Abhijit Kulkarni
Jiuan is offline   Reply With Quote
Old   August 5, 2009, 04:37
Alkulkarni
I have installed Microsoft visual studio on both 64 bit and 32 bit machine. The window for commond prompt is not available.
Old   August 5, 2009, 07:49
Daniel Tanner
Daniel Tanner is on a distinguished road
Try opening fluent from a Visual studio terminal, something like:
start -> All Programs -> Visual Studio -> Visual studio Tools ...
This will ensure that the environment is properly configured and that the Visual Studio compilers are available to fluent.
launch fluent using the standard command line options, something like:
fluent 3ddp -64
If you want 64-bit you should open the 64-bit Visual Studio terminal.
Let me know if this works!
Daniel Tanner is offline   Reply With Quote
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
Error compile file udf czfluent Fluent UDF and Scheme Programming 24 September 26, 2009 13:24
udf compile in parallel system tahereh FLUENT 1 December 9, 2008 09:48
Can someone PLEASE document the development version installation bernd OpenFOAM Installation 76 November 14, 2008 21:51
compile the UDF Li Jingping FLUENT 2 April 14, 2003 21:18
