August 6, 2009, 09:31 |
mesh file
SIVALINGAM
Rep Power: 16 |
This was a simple question to many, i was having only mesh files for some designs and i have to modify it for some work, i have to get dbs file format out of msh file, Will it be possible ? Or to open msh file in Gambit.If yes give me some step by step approach. Thanks in advance. CFD groups cheers.
August 11, 2009, 04:39 |
Rep Power: 16 |
You can import a mesh file in Gambit : File>Import>Mesh... and then chose the right solver, 2d or 3d and browse your mesh file. If you want to change the geometry you may have to delete the old mesh before. Tom38 |
August 14, 2009, 08:29 |
SIVALINGAM
Rep Power: 16 |
Thanks for your answer but after the details of mesh, it need gambit,fluent5/6, etc what i have to opt in that part, thanks once again
August 14, 2009, 15:18 |
Rep Power: 16 |
I don't really understand what you mean but:
- if you talk about the option before importing the mesh under Gambit then choose the solver you used before - if you talk about the option after remeshing your geometry, then choose the solver you'll use. Regards Tom |
STL File - Mesh Surface Problems | Harmeet | FLUENT | 8 | May 13, 2010 21:59 |
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise | mbeaudoin | OpenFOAM Installation | 20 | June 17, 2008 06:43 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
