-   -   Divergence Only with Second Order Discretization (http://www.cfd-online.com/Forums/fluent/67188-divergence-only-second-order-discretization.html)
RyGuy August 6, 2009 11:03
Hello All,
I am simulating a single phase supersonic gas flow in a convergent-divergent de-Laval type nozzle.
I am using the density based implicit formulation (2D, steady state), along with the standard k-epsilon viscous model. I have defined the ideal gas law for compressible flow in the Density field for the Gas (in the materials panel) along with the Sutherland viscosity law. I defined the operating pressure to be atmospheric. As well, I have enabled the Intensity & Hydraulic Diameter option in the drop down menu for the boundary conditions (due to the internal flow of my simulation)
Boundary Conditions are as follows:
Main Inlet - pressure of 6.15 atm and temperature of 500 K, intensity ratio of 3% and the default hydraulic diameter of 1m.
Outlet - atmospheric gauge pressure and 300 K, intensity ratio of 3% and the default hydraulic diameter of 1m.
Walls - enabled specified shear and temperature.
My Problem:
After the solution has converged using first order discretization, I change to second order discretization for improved accuracy and iterate again. To my dismay, the solution diverges quickly even when Fluent reduces the Courant number as low as 0.05.
Therefore, I propose the following questions:
1 - Why does the solution not converge using second order?
2 - Is there something wrong with my set-up that would cause the solution to converge with first order but diverge with second order?
3 - How do I fix this?
If anyone can help me with this topic it would be greatly appreciated...
Thanks,
Ryan
