unusual mesh motion...............help me out
Old   August 7, 2009, 21:52
Question unusual mesh motion...............help me out
abdul samad
samad87 is on a distinguished road
i'm carrying out aero-acoustic analysis to engine turbine...
the single stage 2-d case went well but while i ws doin the multisatge(2-stages) case a strange problem appeared...
the first rotor which had interfaces on both sides started moving in the x-direction once i previewed the mesh motion....i ws using the sliding mesh approach n had given the velocity only in -y direction...the second rotor however showed the normal motion....
i hv tried numerous things including emtying the domain (removing the stators n rotors), then changing teh mesh from pave to map,still teh motion is x-axis motion is thre.....the interesting thing is tht the problem is thre even b4 iterating the file for solution........
desparately need help
samad87 is offline   Reply With Quote
Old   August 10, 2009, 01:02
-mAx-'s Avatar
Maxime Perelli
I think this an geometry issue or a set up issue.
But not a mesh or solver one.
You said the first rotor has 2 interfaces on both sides. The second rotor doesn't give problem, but it is defined as well as the first?
post a picture of your issue
Dynamic moving mesh Pei-Ying Hsieh (Hsieh) OpenFOAM Running, Solving & CFD 64 June 7, 2012 10:04
Fixed mesh method for rigid body motion philippose OpenFOAM 1 January 12, 2009 04:57
mesh motion Mark CFX 1 October 14, 2008 21:52
General question regarding Fluent 6.3s mesh motion AndyRoth FLUENT 0 December 8, 2006 12:01
problem with Mesh motion, please help me! Giuliano FLUENT 2 November 17, 2006 02:44
