-   -   Fluent udf--assigning u-velocity to uds (http://www.cfd-online.com/Forums/fluent/67284-fluent-udf-assigning-u-velocity-uds.html)
tas38 August 10, 2009 15:46
I was working with a Fluent udf that involved assigning the flow primitive, u-velocity, to a uds.
C_UDSI(c,t,0)=C_U(c,t)
However, when I plot the user-defined scalar within Fluent, the value is not close to the theoretical value for u-velocity. Additionally, the plot of of the uds looks does not match the plot of X-velocity.
Has anyone encountered this problem before?
I do not want to continue writing my udf if the assignments to user-defined scalars may not be accurate.
I hooked the udf to a simple test case of couette flow. The visous flow is between a stationary bottom plate and a top plate moving the x-direction at 1 m/s. The distance between the plates is 0.001 meters. Taking a Line Rake of points along the midline of the geometry, X-velocity ranges from 0 at the bottom stationary plate to 1 at the top plate--this is in agreement with theory. User-defined scalar 0, however, ranges from 0.4491 at the bottom plate to 0.5168 at the top plate?
coglione August 11, 2009 10:41
Hello Troy
be aware that if you define a UDS Fluent will solve a transport equation for this scalar. Therefore C_UDSI(c,t,0)=C_U(c,t) is only true at the moment this assignment is executed in your udf (which one do you use?) but values will be updated every iteration/timestep performed.
cheers
