boundary condition for define_grid_motion
Old   August 11, 2009, 10:31
Default boundary condition for define_grid_motion
bongo is on a distinguished road
I am messing around with deformable grids as I am trying to simulate a system with a moving boundary. I believe that I need to use DEFINE_GRID_MOTION as the nodes on my boundary move relative to one another. I have check the tutorial and managed to run a test case with the wall moving with each time-step. However, I am a little concerned. I have set the coordinates of each node using NODE_COORD(v) and nothing else. If the wall is moving with a certain velocity, then should this velocity not be imparting momentum on the fluid? Can fluent calculate the velocity of the wall based on the time step and change of the nodes co-ordinate?
I have performed a similar simulation using DEFINE_CG_MOTION and set the velocity of the moving wall explicitly.
I am certain that fluent needs a wall velocity for a moving wall to set the correct boundary condition. Has anyone any thoughts?
bongo is offline   Reply With Quote
Old   June 12, 2013, 03:37
benjamin_ is on a distinguished road
Hi Bongo,
I'm currently experiencing the same issue :
DEFINE_GRID_MOTION on a cell block , for the mesh movement it's OK , but I've a 0 velocity on the moving wall , so a wrong shear stress...
Did you solve this at this time (4years ago...)?
Regards
Ben
benjamin_ is offline   Reply With Quote
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 05:05
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 11:44
pressure boundary condition in fractional step Jean-François Corbett Main CFD Forum 3 January 10, 2006 08:49
1 and 2 Order Boundary condition at the same place CFD_Flo Main CFD Forum 4 July 11, 2005 11:57
How to resolve boundary condition problem? sam FLUENT 2 July 20, 2003 02:19
