Simulating Falling Object
Old   August 11, 2009, 13:34
Question Simulating Falling Object
scarllatti is on a distinguished road
Hello
I am totally new to CFD but actually I wanted to simulate something that I think shouldn't be very hard. I have access to Fluent and Ansys but I am completely unfamiliar to that. I want to simulate a falling object let's say a disk. I want to show when a disk falls how drag and lift forces act on this disk and by doing that I want to investigate tumbles and flutters in the motion of this disk. If someone please tell me how should I start which softwares should I use. Is there any tutorials.
Please help me
Thanks very very much
scarllatti is offline   Reply With Quote
Old   August 12, 2009, 01:13
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
you may use moving dynamic mesh with 6dof option.
There is a tutorial about 6dof on the fluentusers website
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   August 12, 2009, 07:29
JP
srjp is on a distinguished road
If the object is uniform (like a sphere), you can simulate it by keeping the solid stationary and the fluid to move over the object with the same velocity.
You can try this as an initial solution. This will give you the lift and drag forces on the object, but this will not capture the movements in the object.
srjp is offline   Reply With Quote
Old   August 12, 2009, 13:43
Question
Thanks a lot for your replies. Actually I want to create a disk and then I want show the motion of this disk because of fluid forces like drag and lift when this item falls so I want my object to move in fluid because of gravity and then calculate fluid forces on it. so I want a to solve Navier-Stokes equations for a falling paper. Unfortunately I don't have fluentusers login and pass so I don't have any access to it's tutorials so I would appreciate if someone can help me finding the tutorials that might be helpful because I am totally new to Fluent.
-mAx- I think using moving dynamic mesh with 6dof would be a good option but unfortunantely I don't know how I should do it and I don't have access to the tutorials so if you can help me a little bit more I will be very grateful.
Thanks a lot
Old   August 12, 2009, 21:16
Default Simulation In CFD
jitukrjain
jitukr is on a distinguished road
Don't plan to give velocity to disc. give opposite velocity to fluid in fluent. or else try your hands on ansys 12 workbench which is easier to work
jitukr is offline   Reply With Quote
Old   August 12, 2009, 22:25
Question
Actually I want to simulate something like this :
http://www.geocities.com/joeyhuang2001/java.html
but in 3D preferably.I appreciate you if you can help me with that and tell me how should I start and which tools should I use and refer me to some tutorials if it's possible.
Old   August 13, 2009, 03:47
-mAx-'s Avatar
Maxime Perelli
Thanks a lot
We switched to OpenFOAM, so we don't have access to fluentusers anymore
Old   August 13, 2009, 11:23
Question
Actually I have access to openfoam too and I did a tutorial on it so if you can help me with that it would be very helpful too. I thought fluent maybe a little bit easier but if you can guide me to how to start with openfoam that will be very very good too.
Thanks
Old   August 14, 2009, 03:25
Default Animation of falling object
jitukrjain
Try ansys 12 WB. It is easiest. or else try Comsol 3.5 or above. Here u have to design PDEs but solution is possible. Check there training manuals or install Ansys WB 12 and then go through initial tutorials and then refer back. Your problem will be solved.
Compilation error OF1.5-dev on Suse10.3 darenyang OpenFOAM Installation 0 April 29, 2009 04:55
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
OpenFOAM141dev linking error on IBM AIX 52 matthias OpenFOAM Installation 24 April 28, 2008 15:49
Simulation of object in rotation Dothan FLUENT 4 March 25, 2008 03:25
Temperature blowup for with 6-DOF falling object Andrew Wick FLUENT 3 October 16, 2005 15:56
