Pressure-Velocity coupling -> general question
Old   November 14, 2010, 11:05
Default Pressure-Velocity coupling -> general question
Smith, John
quattro123 is on a distinguished road
Hello, since i dont know exactly how the pressure velocity couplings influence the solution, i tried a experiment.
My test case was a lid-driven cavity where only the lid is moving (the top of the quader) in x-direction.
Now i simulated the same case with the three different coupling algorithms:
SIMPLE, SIMPLEC and PISO.
Then i plotted the velocities of x and y direction on both x and y middle axis to compare them.
The thing is the iteration of the lid.
From a fluent tutorial I have the information to iterate from neither the fluid nor the lid, just put a small value for the x velocity and a very small value for the y velocity.
I did it, i followed the tutorial very carefully and all of my velocity plots look very different. I thought thats okay.
Now i did also another iteration, where i initalized from nothing. i didnt select any item or entered any initial velocity in the initialize window and i iterated.
I thought this makes no chance, except that it will need much more iterations. But then i plotted all the velocities again for the different couplings and i realized that all of them are NEARLY the same, they are very very close the same.
So, which one is the right way to do that?
I guess the velocity couplings have to be different, dont they?
Or will i see just a difference when i use a coarse mesh?
Maybe one can shortly introduce me the basics/difference of the 3 algorithms? i already read the fluent manual, but i understood nothing of this.
Kind regards!
quattro123 is offline   Reply With Quote
Velocity Pressure Coupling Chris Lucas OpenFOAM 1 November 2, 2010 16:14
Pressure Velocity coupling problem Sunho park OpenFOAM Running, Solving & CFD 0 August 4, 2010 00:22
Unsteady flow- pressure velocity coupling Hooman Main CFD Forum 0 June 7, 2010 10:31
Pressure - velocity coupling student CFX 0 March 26, 2008 11:36
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 11:26
