Drag and wind loading???
Old   October 5, 2010, 10:09
Default Drag and wind loading???
Sebastian Bode
Cbas is on a distinguished road
I know this may be a simple question but:
I am designing a parabolic trough. I need to know how wind affects it so that I can size a motor. Ie, i need to know the effect that wind has on causing a torque (moment) about its center of rotation.
This is what I've got:
I used a 2D solver.
CFD post I go to
Calculators>function calculator>Function[Max Val]>Location [Upper surface]>Variable[Force]
Am I correct in saying ANSYS calculates this force from a pressure? In which case, is that pressure given per unit depth because its a 2d situation?
So can I just take that max force, assume it acts on the furtherest point(worst case) and calculate my torque?
Thank you
Cbas is offline   Reply With Quote
Old   April 12, 2014, 22:25
Default wind load on parabolic trough
bassem
kaabya is on a distinguished road
hi there,
I need some help of you expertes .
I am studying wind load on a parabolic solar concentrator at certain angles using Fluent.
I choose to start with the 2D simulation in order to evalate the drag and lift coefficient.
I have some troubles :
1. I don't find a logical drag coefficient value. It seems related to the references values. How can I set up those values in my case ?
2. If the 2D simulation is sufficient to find a good results ?
Thank you for advance
Bassem
kaabya is offline   Reply With Quote
parabolic trough, torque, wind loading
Drag force on scaled models. arunjingade Main CFD Forum 6 July 1, 2010 08:54
drag coefficient Amir FLUENT 6 November 7, 2008 05:47
Drag calculation in 3D bvirtual wind tunnelb optimistx OpenFOAM 1 November 6, 2006 04:06
can phoenics simulate lake flow under wind drag wady Phoenics 3 August 17, 2004 06:37
Please help a newbie find the drag on a 3d model David Amer Main CFD Forum 1 March 6, 2002 03:33
