March 8, 2007, 12:45 |
Stream Functions in a 3D problem
Hi everybody Dear! I want to see the contours of STREAM FUNCTIONS.
The problem is that my problem is 3D so I donot get any option for Stream function under Velocity Cant it happen that I make a plane and observe Stream Function contours on it? Please help me or if you have any suggestions? |
March 9, 2007, 04:10 |
Re: Stream Functions in a 3D problem
The Stream Function is not defined in 3D since it is only a 2D flow representation.
March 10, 2007, 10:43 |
Ok sir, I know that all. and I got your answer but cant I see Stream Functions on a plane. I am still annoyed because I saw a paper in which a 3D problem was done and stream functions were observed! Thanks
March 13, 2007, 16:51 |
you can plot the "pathlines" for your 3D case... serves the same purpose for flow visualization.
March 14, 2007, 04:20 |
Oil flow on surface maybe?
August 16, 2009, 13:49 |
draw velocity vector, streamline and stream function
Hussam
Rep Power: 17 |
Dear Sir
My name is Hussam Ali Khalaf, postgraduate student in Iraq and Am currently working on “A Solution Algorithm for Transient Fluid Flow with Multiple Free Boundaries” I have results for velocities values (u and v) in directions x and y for undular bore evolution (please, note the file attachment), rectangular uniform mesh (2Dimension, (i,j)=(22,10)) consists of 20 cells in the horizontal direction (length=12 , ∆x=0.6) and 8 cells in the vertical direction (height=1.6, ∆y=0.2). Am supposed to draw velocity vector, streamline and stream function. I have a program TecPLOT, I have tried several times but I don’t fully understand how TecPLOT reads the results, would you please help me if you have any idea on how to go about it. Thank in advance Yours sincerely Hussam Ali Khalaf Iraq |
Display Modes | |
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 | maverick | OpenFOAM Meshing & Mesh Conversion | 2 | June 18, 2011 05:36 |
Can I solve this problem by Fluent? | Kai_kc | FLUENT | 1 | October 27, 2010 06:29 |
Coordination Frame Problem - strange | Luk_Fiz | CFX | 2 | July 30, 2010 09:20 |
Velocity profiles problem behind the elbow (3D problem) | kabat73 | FLUENT | 8 | May 9, 2010 05:26 |
N-S equations:divergence free functions? | D. Puigjaner | Main CFD Forum | 1 | July 27, 2000 13:43 |
