November 11, 2007, 12:07 |
Lifted flame simulation!!!
Hi i am trying to simulate non premixed confined turbulent propane lifted flames. I am using species transport model and in that laminar finite rate model for turbulent chemistry interactions. But the flame is not getting lifted upon increasing the velocity beyond 25m/s and the simulation lift off height is not matching with experimental lift off height. For 25m/s fuel velocity and pressure inlet condition for air,single step chemistry,k-e turbulent model: Experimental height =96mm Simulation lift off height=50mm. why this much discrepancy between experimental and simulation results. I tried with eddy dissipation model;laminar finite rate/k-e model;eddy dissipation model;EDC model. out of which i can achieve lift off of flame only when i am using laminar finite rate model or EDC model but EDC is over predicting the results. can u suggest me what i need to do to achieve correct lift off height(i.e my suggesting any particular model or the changes i need to make)
August 26, 2009, 06:17 |
hi
siva kumar
Rep Power: 16 |
send ur experimental results and gepmetry,, i will say the correct solution,,,
moreover hav u considered any wall thickness??? my email id is :shshiva17@gmail.com |
Display Modes | |
ReactingFoam Laminar flame simulation transport properties | gbansal | OpenFOAM Running, Solving & CFD | 3 | November 23, 2012 17:03 |
GUI crash and simulation engine still running | RPJones | FLOW-3D | 2 | November 9, 2010 09:18 |
velocity profile export from a simulation onto another | sudhirlv | STAR-CCM+ | 1 | September 12, 2010 19:57 |
combustion bomb simulation ... | bart_weisser | FLUENT | 0 | April 25, 2010 03:41 |
strange simulation error | Ralf Schmidt | FLUENT | 2 | May 4, 2007 14:02 |
