Fire Simulation Problems
Old   August 23, 2009, 22:15
Default Fire Simulation Problems
alkidos is on a distinguished road
Hi. I was wondering if someone could help me with the problems I've been having modeling an open air flame (pool fire).
I've been using the k-e model with eddy dissipation for the model. I modelled everything in steady state with gravity off and switched to a transient solution with gravity and radiation turned on. The solution, however, does not change from the steady state if I put a time scale of .001 seconds. If I put a larger time scale, the solution will change, but will not converge in each time step.
Also, what's the best approach to model the flame. A cold flow first? I've taken this approach but havn't gotten good results.
alkidos is offline   Reply With Quote
Old   August 25, 2009, 19:26
anonym
Laci is on a distinguished road
If you find the longer time scale, when the solution still converge, you shouldn't increase it anymore.
Laci is offline   Reply With Quote
fire simulation preibie FLUENT 6 May 29, 2010 05:37
problems of turbo simulation in CFX-10 Qiang CFX 0 September 11, 2006 23:19
what's the best commerical CFD software for fire? yin rumin Main CFD Forum 5 October 12, 2000 17:12
3-D Contaminant Dispersal Simulation Apple L S Chan Main CFD Forum 1 December 23, 1998 10:06
Fire Simulation Loh Main CFD Forum 6 December 4, 1998 06:07
