hydraulic diameter in 2d
Old   August 28, 2009, 02:44
Default hydraulic diameter in 2d
ahsan ikram
ahsan is on a distinguished road
hi all
i am working on a 2D case of the fluidization of charcoal. In order to specify the turbulance specification at velocity inlet, i have to specify the value of hydraulic diameter. In 3d, inlet is a circular duct. Problem is that how i can define the hydraulic diameter for 2D case at velocity inlet edge.
In the tutorial 01 of fluent6.2, i have found that the wetted perimeter will always be 2 for a circular inlet in 2D case regardless of whatever is inlet diameter. Also the hydraulic dimeter will be 2 times the diameter of the circular inelt.
In some other tutorials, i found that the hydraulic diameter will be double of actual diameter for a 2D case.
plz guide me that how this hydraulic dimeter will be double for a 2D case and how this wetted perimeter is 2.
regards
Ahsan
ahsan is offline   Reply With Quote
Old   August 28, 2009, 03:14
Max
coglione is on a distinguished road
Hello ahsan
to specify turbulence correctly at inlets using intensity and hydraulic diameter you always have take the actual, physical dimensions. If your inlet geometry is a circle then take its diameter, no matter if you are using a 2-D or 3-d model to simulate the problem.
cheers
coglione is offline   Reply With Quote
Old   August 28, 2009, 15:22
ahsan ikram
hi coglione
thanx for guidence
ahsan
Hydraulic Diameter - Series of Holes Jop FLUENT 6 January 14, 2019 09:41
Importance of Hydraulic Diameter Value for Compressible Flow RyGuy FLUENT 0 August 6, 2009 10:58
Hydraulic diameter OFXJ FLUENT 1 September 30, 2008 00:56
What is hydraulic diameter and reference value? vincent FLUENT 1 October 1, 2007 09:59
Hydraulic diameter for external flow. pah FLUENT 0 July 20, 2005 04:27
