Wall BC in Fluent
Old   August 30, 2009, 02:12
Default Wall BC in Fluent
Hugo E. Pelaez
a00884062 is on a distinguished road
Send a message via Skype™ to a00884062
Hi.
Is it possible to set a wall boundary condition in which the temperature of the wall is changing with time (or in other words, can the temperature be updated with every iteration?). I also do not know the heat flux.
I am trying to solve a problem where I have a coil filled with Liquid Nitrogen and I am trying to find the temperature in the center of the coil.
Any ideas or suggestions?
Hugo
a00884062 is offline   Reply With Quote
Old   August 30, 2009, 04:03
MOHSEN Zendehbad
mohsen zendehbad is on a distinguished road
refer to the fluent document, udf help. read the material related to the DEFINE_PROFILE. you can easily find it in its index. you can't change the temperature in each iteration but you can define a fuction for temperature which changes with time. you may find the same codes in its examples.
mohsen zendehbad is offline   Reply With Quote
Natural Convection over a vertical wall Sireesha Pasari FLUENT 2 July 15, 2012 16:31
Heat transfer BC at wall- why need wall thickness? Julie FLUENT 7 February 3, 2012 21:41
Fluent creating wall zone on mesh import? Mark FLUENT 4 April 4, 2005 07:14
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
wall and wall:** in "Grid display" panel of FLUENT sean FLUENT 0 March 23, 2001 02:05
