Adapt-gradient
Old   August 31, 2009, 15:57
Question Adapt-gradient
vishwanath somashekar
vishwa is on a distinguished road
i am running a LES simulation on a cluster. I have ran it for some time now and I wanted to adapt gradient based on velocity.
Here is how i did that..
On a local machine, I
Read the .cas file
Read the latest .dat file
Then did the adapt -gradient based on velocity and computed the max and min values. then gave the threshold value as about 10% of the maximum value.
there were a whole bunch of cells which were modified.
Here is what I didn't not understand. How do I restart the case on the cluster. I got a segmentation violation when i did the following.
On the local machine, after adapting the grid, I save the case file and the data file and the then copied to the computer cluster.
Is there a way of doing this adapt-gradient in batch mode?
As always, thanks a tonne..
vishwa
vishwa is offline   Reply With Quote
Pressure Gradient in channelOodles sega OpenFOAM Running, Solving & CFD 14 August 12, 2009 06:21
can I use static enthalpy gradient to describe dT Jay CFX 0 August 6, 2008 23:01
Adapt gradient and time plot. Sham FLUENT 2 April 14, 2005 12:43
How to compute gradient for non-orthogonal grids? Paul Hsieh Main CFD Forum 3 November 11, 2003 04:52
pressure gradient term in low speed flow Atit Koonsrisuk Main CFD Forum 2 January 10, 2002 10:52
