Home > Forums > FLUENT
Error: cx-add-item: wta[2](string)
Old   February 16, 2007, 03:33
Default Error: cx-add-item: wta[2](string)
Claud
Hello, I am trying to model a laminar flow for a test plant consisting of CH4, CO, CO2, H2 and water vapor. Therefore I tried to include new material properties for the just mentioned gases. That results in the error "cx-set-list-items: wta[2](list of strings)". Does anybody have an idea how I could solve that problem? Thanx in advance! Claud
Old   September 1, 2009, 12:09
Rodrigo Bocaz
rodrigobocaz is on a distinguished road
Hi, can some one help me with this error, it appears when y launch fluent 6.3.26 on windows Vista X64.
The complete message is:
Welcome to Fluent 6.3.26
Copyright 2006 Fluent Inc.
All Rights Reserved
Loading "C:\Fluent.Inc\fluent6.3.26\lib\fl_s1119-64.dmp"
Done.
Error Object: 1204
Error Object: 1204
Thanks, i will apreciate any help.
rodrigobocaz is offline   Reply With Quote
Old   October 28, 2009, 05:43
Thumbs up cortex problem (Error: cx-add-item: wta[2](string) )
Mohamed Hendawi
Hendawi is on a distinguished road
All Rights Reserved
Done.
Error Object: 1204
Error Object: 1204
I have the same problem : please cf. the attached screen-shot
I checked that:
  1. the %USERPROFILE%\.flxxxx is absent
  2. the %USERPROFILE%\cxlayout is absent too
Any help please
Thank you
Edited:
Finally, the problem was resolved by deleting .
cxlayout and .flrecent found in %HOMDEDRIVE% (some where like a private local default user drive)
Good luck
Hendawi is offline   Reply With Quote
Old   June 17, 2015, 04:45
Default Problem not solved
riccardo
difficult27 is on a distinguished road
Good morning guys. I have followed your indications but I have always the same problem. Every time that i read the case and data the same error appears. I have deleted the file that you have told but nothing change. How can i fix this? Thank you!
difficult27 is offline   Reply With Quote
Thread Tools
Trackbacks are On
pyFoam and paraview eelcovv OpenFOAM Paraview & paraFoam 28 May 30, 2016 09:23
refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 0 April 27, 2015 18:25
How to add X and Y forces at a point cgusty01 SU2 4 February 18, 2015 14:17
[ICEM] How can I define different zones in ICEM? llrr ANSYS Meshing & Geometry 13 August 4, 2014 20:04
Can not add a new user defined visualization parameter in Cut plot! george85 FloEFD, FloWorks & FloTHERM 5 November 9, 2011 14:33
