September 11, 2009, 07:31 |
Multiple Shape Volume Mesh
Rich
Rep Power: 16 |
I'm battling to mesh a volume that consists of prismic and quad volumes. I wanted to use cooper mesh but it couldn't work. Most examples that I've seen where they mesha vlome with different shapes they use cooper. But i think the problem is the version of Fuent software that I'm using. I'm using Fluent 6.3.26, and modeling using Gambit 2.4.6. It's just that teh examples i've seen don't indicate what software version they were using. If I were to use cooper mesh, I should identify sources, but the software version I'm using doesn't have the sources feature.
Can someone please advise what should I do? Thanking you in advance. |
September 11, 2009, 07:36 |
Svetlin Filipov
Rep Power: 17 |
Meshing with Cooper scheme needs some special points. The problem is not in the GAMBIT version... post the geometry and I'll try to help.... be aware that you need to mesh some faces with QUAD MAP for example....
September 11, 2009, 08:45 |
Rich
Rep Power: 16 |
Thank you very much. I wanted to attach a diagram in teh original message but couldn't get an icon for attachment. Do you may be know how to attach an image when posting a thread?
September 11, 2009, 09:02 |
Svetlin Filipov
Rep Power: 17 |
Below the place you write the post there is are "Additional options"
September 14, 2009, 03:19 |
Rich
Rep Power: 16 |
Thank you very much. I've now attached the pictures of the model.
September 14, 2009, 03:57 |
Maxime Perelli
Rep Power: 41 |
Do you have one volume, or more?
In other words, is your geometry already splitted? If your geometry is well splitted, gambit will automatically choose the right mesh-scheme adapted to selected sub-volume. In your case, it should select hex-cooper
In memory of my friend Hervé: CFD engineer & freerider |
September 14, 2009, 04:08 |
Svetlin Filipov
Rep Power: 17 |
What kind of task are you going to perform?
September 14, 2009, 04:55 |
Rich
Rep Power: 16 |
No, I only have one volume. The geometry is not split. I'm using Gambit 2.4.6, this is an older version. The lates version I've hear that it does automesh a geometry. The old versions could easily perform cooper mesh, but this version doesn't because there's no feature that allows one to identify sources. That's setbackin trying to cooper mesh this volume.
September 14, 2009, 04:58 |
#9 |
Rich
Rep Power: 16 |
I'm cooling a hot surface using microchannel heat sinks. The heat sinks have a tree-shaped structure. The coolant medium is water.
September 14, 2009, 05:13 |
#10 | |
Maxime Perelli
Rep Power: 41 |
forget trying to mesh your model on the fly... you won't achieve to get a mesh even if you choose tetra cells. You have to split your model into several basic sub-volumes which can be easily meshed with hex-cooper. Your geometry is brick-shaped, so it won't be difficult, but you will have to spend more time, than just cliking on one button and waiting
September 14, 2009, 06:10 |
#11 | |
Svetlin Filipov
Rep Power: 17 |
[Netgen] Volume mesh instead of surface mesh | phan | OpenFOAM Meshing & Mesh Conversion | 4 | October 18, 2009 17:17 |
negative volume found in es-ice mesh | lizhihua | Siemens | 1 | August 4, 2007 04:39 |
Dynamic Mesh, negative volume! | ROOZBEH | FLUENT | 2 | June 22, 2006 20:51 |
How to obtain the same volume of mesh | Dome | CFX | 0 | April 22, 2005 13:32 |
different mesh types in one volume | mp | FLUENT | 2 | December 20, 2002 18:11 |
