how do i create fire in fluent to simulate smoke
Like Tree1Likes
  • 1 Post By zongtwi
Old   December 31, 2008, 05:19
Default how do i create fire in fluent to simulate smoke
david
Hi all,
Does someone can help in this matter? This is my assigment and I'm new to CFD. How do I create fire in Fluent to simulate the smoke dispersion. Pls help me.....
Old   January 1, 2009, 06:22
Default Re: how do i create fire in fluent to simulate smo
zongtwi
You can either use the combustion models available to simulate the fire, or you can model the fire as a fluid zone with a heat generation source.
Hope that helps.
happy likes this.
Old   June 3, 2009, 10:00
Default Car ParK Simulation
Abdelkader Benzamia
metco is on a distinguished road
Hello Evry Body
I am doing for a car park smulation.
To simulate the smoke? I put a passif scalar as smoke with velocity and temperature are equal : 1m:s ans 700 K.
I want a real case, I want to see the mass fraction of Co ans Nox, Visibility
I want to the full job in this kind of problems.
Please help me
metco is offline   Reply With Quote
Old   June 4, 2009, 02:03
Default smoke spreding
Philipov's Avatar
Svetlin Filipov
Philipov is on a distinguished road
For gas distribution use multiphase model and define all species that you want. I think it is not necessary to model the real flame... this will not give you more information but will give you modeling problems.
Philipov is offline   Reply With Quote
Old   June 4, 2009, 02:38
Abdelkader Benzamia
Thank you for your reply,
To simulate a real case can you help me to put the right data.
Mass fraction of co, and nox ..., Masse flow, or velocity, and temperature.
Thank you again.
Old   June 4, 2009, 03:06
Philipov's Avatar
Svetlin Filipov
Species fractions depends on what is burning, conditions of combustion, air speed and many others ... if you model an exact combustion process your task will be very very specific.... if you what to model smoke distribution then take typical gas fractions in combustion of the fuel you want, take typical BC (heat source, velocities, Pressure...)and use unsteady solver...
Old   June 4, 2009, 03:21
Abdelkader Benzamia
Thank you againe.
This is my provleme, advice me please,
Advice me for a real case and boundary conditions. thank you so match
Old   June 4, 2009, 03:34
Philipov's Avatar
Svetlin Filipov
Give me scheme of the situation, type of fuel, place of burning....
Old   June 4, 2009, 03:41
Abdelkader Benzamia
A real case for car park scenario.
Thank's
Old   June 4, 2009, 03:46
Philipov's Avatar
Svetlin Filipov
if you want someone to help you must be more informative... what is the type of fuel that is the source of the fire...
Abdelkader Benzamia
Let's take a combustion of methane for example.
Old   June 4, 2009, 03:56
Philipov's Avatar
Svetlin Filipov
It is not possible to say (let's say methane)!!!!!!!!!! products from methane combustion are CO2 and H2O ... so in that case you what to model CO2 distribution so... you just model air and CO2 with let's say 0.02 kg/s... with the information you give I can not do more..
Old   June 4, 2009, 04:03
Abdelkader Benzamia
I will comback to you form details,
I wil try to be clear, the problem is this kind of situation is new for me.
I have looked for other publications and the show only results without details of boundary conditions.
Thank you very match againe.
Old   October 9, 2009, 14:28
Abdelkader Benzamia
I comback to you withe more details about my simulation.
Fire scenario inside a tunnel :
burning 500 l of diesel in 6 min
average released power of 44.4 MW
The fire is modelled using a volumetric
How could i set up those boundary conditions in fluent
Best
Thank you for all.
Old   May 28, 2010, 02:31
S.M.Sumon
mesumon203 is on a distinguished road
I wanna model a fire placed at the bottom of a sealed room. how can i do do and do u know about any tutorial or related paper of it
please help me. i am new in this things
mesumon203 is offline   Reply With Quote
Fire & Smoke in Building Jenn FLUENT 5 December 29, 2012 23:15
smoke (fire simulation) matt Fidelity CFD 0 January 5, 2007 04:47
smoke (fire simulation) matt Main CFD Forum 0 January 5, 2007 04:45
Could FLUENT simulate the smoke? Saturn FLUENT 0 July 13, 2004 00:30
Fire/Smoke Modelling Roger Siemens 1 November 27, 2002 02:37
